Farmall Tractors Discussion Board
Re: C113 or C123 : Is this the original motor in my Super A?
Posted by Jim Becker on February 16, 1999 at 19:25:07:
In Reply to: C113 or C123 : Is this the original motor in my Super A? posted by Daniel on February 15, 1999 at 18:04:44:
I'd be curious as to what Guy Fay has to say on this one.
My notes say the C-113 block is 251 069 R1 and the C-123 block is 354 898 R1. Ignoring one mis-read digit somewhere, it looks like you have a C-123 engine. The engine number is close enough to the tractor serial number to be believable for the original engine. But there is no evidence to date that C-123s were installed in Super As. The "FAAM" on the engine number implies it was not moved from a Super C as the Super C engine should have been marked "FCM." Several possibilities come to mind, in no particular order:
1) A few of the last Cs had the C-123 engine installed, maybe they tried a few in some Super As at the same time.
2) Since Super Cs were being made with the C-123 at the same time, maybe it was installed by mistake.
3) The engine was replaced. Whole replacement engines came with stamped engine numbers, but parts weren't. Possibly it got a new bottom end and whoever did the work restamped the original engine number into the new block.
Check the block for a date code and see how it compares to the codes on other major castings.
Post a Followup
: Re: Re: C113 or C123 : Is this the original motor in my Super A?
