Farmall Tractors Discussion Board
Re: Starter for a 1941 Farmall A
Posted by Stan(VA) on February 17, 1999 at 05:19:35:
In Reply to: Starter for a 1941 Farmall A posted by Ray Matchell on February 17, 1999 at 05:04:12:
You need to swap your bellhousing for one with the starter hole from a later A or B. Check with a salvage yard. The ring gear is still available to be mounted on your flywheel, costs about $30. You would need to split the tractor to both of these jobs. If you need help with part numbers, etc, get back to me.
Stan(VA).
Post a Followup
: Re: Re: Starter for a 1941 Farmall A
