Farmall Tractors Discussion Board
Re: Farmall A starting problem
Posted by Curt Cooke on February 17, 1999 at 05:38:35:
In Reply to: Farmall A starting problem posted by Todd Stellhorn on February 16, 1999 at 22:59:32:
I doubt that the problem is flooding, except that if you crank it long enough without ignition, you can eventually flood it. Todd, be sure that your breaker points are in good shape, replace if necessary, then try some different plugs. I've found, for instance, that a D15Y plug is great for cold hand starts but after that they're not. But I would try different ones than you're using now. Flooding should not occur.
Post a Followup
: Re: Re: Farmall A starting problem
