Farmall Tractors Discussion Board
Re: Farmall A starting problem
Posted by Nate on February 17, 1999 at 11:20:00:
In Reply to: Farmall A starting problem posted by Todd Stellhorn on February 16, 1999 at 22:59:32:
Before you go changing much, make sure you cut the throttle down to the lowest idle before killing the ignition. When it's open the engine keeps sucking in gas but not burning it because it's spinning pretty good still. When it's idling slowly, less gas is going in and it doesn't continue to spin for so long either.
Post a Followup
: Re: Re: Farmall A starting problem
