Re: mccormik 10-20 pistons
Posted by spiffy1 on March 14, 2009 at 22:48:57 from (70.41.137.72):
In Reply to: mccormik 10-20 pistons posted by karl f on March 14, 2009 at 18:24:05:
Re-reading your original post, I'd concur with the above posts:
Note the piston locations if they aren't already marked, remove the rings and clean them and the grooves on each one.
Keep the shim stack locations as previously noted, but Plasti-gage is cheap (a $2.00 strip should do all 4 with a couple trys each) so you can set them easy enough.
Have fun!
