Farmall Tractors Discussion Board
Re: Hard/soft water
Posted by DM on February 19, 1999 at 20:38:49:
In Reply to: Hard/soft water posted by Pete B. on January 01, 1999 at 18:44:16:
Have you ever had a problem with a car or other water cooled engine having heating problems. If you have, you have reason to want to use distilled water in your radiator. Tap water, in most cases, has large amounts of calcium and other minerals in it. It causes scaling in radiator cores as well as water jackets of the engine block. Antifreeze solution helps to a point, but when you have an iron block that is partially rusty, don't make the situation worse. The same is true for your batteries. If they need water, it should be pure. Electrolyte comes from the Sulfuric Acid that is added to new batteries. I would not reccomend using softened water for fillups. I do not think you can be sure how well the salt is flushed out after the regeneration cycle.
Post a Followup
: Re: Re: Hard/soft water
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
