Re: Should I replace this clutch??
Posted by El Toro on March 15, 2009 at 04:47:04 from (205.188.116.73):
In Reply to: Should I replace this clutch?? posted by Butch WI on March 14, 2009 at 13:58:44:
I would at least take a look at the clutch disc to see if its worn and getting close to the rivets. You can also inspect the surface of the flywheel. Cold and light rain here in MD. APG is putting up new buildings pdq for all the new transfers from NJ. Hal
