Farmall Tractors Discussion Board
Re: Re: Re: 1468 V8 ENGINE
Posted by Tom on February 20, 1999 at 11:59:22:
In Reply to: Re: Re: 1468 V8 ENGINE posted by JEFF on February 20, 1999 at 09:42:33:
Jeff it is a rule that when you put undo pressure on a engine(turbo)that you cut the life in half unless the motor is made for turbos.The v8 is fine as long as it is left alone,but you get yahoos turning up the pump,putting turbos on and the motor comes apart,thats why you need the basket.If it was me i would leave the turbos alone.Good luck
Post a Followup
: Re: Re: Re: Re: 1468 V8 ENGINE
