Farmall Tractors Discussion Board
Re: IH 815
Posted by Ralph on February 20, 1999 at 20:59:37:
In Reply to: IH 815 posted by JEFF on February 20, 1999 at 09:49:51:
Depends on which heads, if a pick up head how is the pick-up? We ran two 815s for many years not a bad machine. The weakest part is the hollow shaft in the hydro up by the engine. If it is a gas model it probably will have the 345 truck engine. A very good engine. If you let them get dirty in the engine area they will catch fire. If they do don't shut them off just get back there and use the fire extinguisher, then pull the coil wire to make sure the fire is out. The worst we done in several thousand acres was burn off a couple of plug wires. Good luck.
Post a Followup
: Re: Re: IH 815
