Farmall Tractors Discussion Board
Re: Super A Valve Lever Question
Posted by K-Mo on February 21, 1999 at 04:57:41:
In Reply to: Super A Valve Lever Question posted by Daniel on February 20, 1999 at 19:17:41:
Daniel,
Your rocker arms can be reground. This can be done by your machine shop. It is important to have them cleaned up otherwise you can't set the valve clearance properly.
I have a Super A if you have any questons I will try to help.
Kent
Post a Followup
: Re: Re: Super A Valve Lever Question
