Re: need help on 49 cub
Posted by Z. A. Bender on June 09, 2001 at 20:24:08 from (208.143.146.176):
In Reply to: need help on 49 cub posted by mike in ga.. on June 09, 2001 at 05:53:02:
Check and see if it might be sucking air around the manifold, I had one do this once, to check it I usually start the tractor and then spray starting fluid around the edge of the manifold, wd-40 will work also. BE CAREFUL, that stuff is dangerous though. If it is sucking air the engine will speed up after it gets a wif of that starting fluid. Good luck!
Post A Followup
: Re: Re: need help on 49 cub
