Re: Re: H verses M
Posted by Pete on June 10, 2001 at 17:19:50 from (66.24.154.121):
In Reply to: Re: H verses M posted by Dan on June 10, 2001 at 13:49:04:
Dan, If you decide an H is the way to go, you should consider a Super C. A little samller in stature, a little handier than a straight H, just about as much HP, but with it's power to weight ratio, capable of about 99.9% of the work that a straight H is. The other thing is that alot of the Super C's had quick hitch, which is aesily convertible to 3pt, and it is one of the best 3pt hitches I have ever used. An M if you need more power or bigger.
Post A Followup
: Re: Re: Re: H verses M
