Re: Need Instructions To Start A WD-9.
Posted by Haas on June 10, 2001 at 17:27:03 from (129.37.117.195):
In Reply to: Need Instructions To Start A WD-9. posted by Carson on June 10, 2001 at 15:10:44:
I have an MD. Never started a WD9, but I assume similar to the MD. First, you put the starting change over lever (That's the lever that switches the engine from gas to diesel) in the gasoline position. Four things occur by moving this lever When in the gas position, valves in the head are opened to a chamber in each cylinder that contains the spark plugs reducing the compression for gasoline operation. A switch is opened to activate the ignition. In diesel operation, the magneto is grounded so no spark. The float in the carburator is release to allow gas to flow to the carb. In diesel position, the float is locked up to cut off the gasoline flow. And finally, butterflys in the manifold are switched to let air flow through the carb. Make sure you have the gas turned on and that the diesel speed control lever is in the shut off position. Then give it some choke and hit the starter. Or if need be, you can pull it with another tractor. Once it's going on gas, fiddle with the choke to keep it running. After 2 or 3 minutes on gas, it should be warm enough to run on diesel. At that point, pull the change over lever to the diesel position and immediately (or at the same time) advance the diesel speed control to at least half throttle. If it all works, you should get a puff of smoke, a loud roar and you'll be running on diesel. When you shut down, it's best to switch back to gas and shut the gas off to the carb and let it run the gas out to kill it. To do that push the diesel speed control to shut off position and at the same time switch the change over lever to gasoline position. After she dies, be sure to move the change over lever back to diesel. THIS IS CRITICAL. THe decompression valves need to be in the diesel position on their seats to cool. Also always idle down for several minutes before shutdown. Shutting down hot is a primary cause of cracked heads I am told. Good luck. Let me know how it goes.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
