Re: cub dies after some work
Posted by Robert on June 11, 2001 at 06:39:11 from (207.43.195.201):
In Reply to: cub dies after some work posted by scott on June 11, 2001 at 06:31:14:
I sounds like a classic case of Vapor Lock. Another possibility could be a thermal problem with the condensor getting hot opening up. It doesn't sound like anything serious. I would try the condensor as they are cheap. If you continue to have the problem, I would suspect a vapor lock in the fuel system. Cool fuel and Hot fuel lines will do it, you could try a heat shield of some type on the lines to combat this.
Post A Followup
: Re: Re: cub dies after some work
