Re: cub dies after some work
Posted by The Red on June 11, 2001 at 07:08:32 from (206.246.187.2):
In Reply to: cub dies after some work posted by scott on June 11, 2001 at 06:31:14:
What weight of oil are you using?
Electrical wise, swap out the condensor for starters. If it konks again in an hour or so, I would suspect the coil is breaking down.
Post A Followup
: Re: Re: cub dies after some work
