Fabricating Steel Wheel Lugs for a 15-30
Posted by Chris on June 11, 2001 at 15:11:27 from (205.200.168.229):
I would like to replace the lugs on a 15-30 I'm restoring but the origional lugs appear to be forged due to the thickened web accross the inside of the peak.
Does anyone think that using a large break to bend 3.5" x 3/8" bar stock to shape will work? I'm a little worried that these lugs may wear out or deform quickly.
Has anyone tried this before?
Would arc welding a bead across the tip and inside the peak help any?
Post A Followup
: Re: Fabricating Steel Wheel Lugs for a 15-30
