Re: Re: Farmall B questions
Posted by Dave T on June 11, 2001 at 15:36:15 from (63.15.161.205):
In Reply to: Re: Farmall B questions posted by Red Dave on June 11, 2001 at 12:57:03:
Before adjusting governor, make sure you have all the parts on your throttle linkage. I was just fixing the same problem you have and found out one of the springs was missing. I replaced the spring and it was close enough to what it should be and didn't need to touch that part, but I have a surge problem that I need to adjust with the screw below the governor...
Post A Followup
: Re: Re: Re: Farmall B questions
