Re: Plough on a Super A not working!
Posted by john on June 11, 2001 at 16:46:59 from (208.235.42.2):
In Reply to: Plough on a Super A not working! posted by Sam on June 11, 2001 at 16:16:33:
FIRST ITS SPELLED "PLOW" NOW ON TO THE GOOD STUFF. MAKE SURE THE PLOW IS POINTING DOWN WHEN YOU LOWER IT . IF ITS SETTING ON THE GROUND AND ANYTHING BUT THE TIP END OF THE PLOW IS TOUCHING THE SURFACE YOU HAVE IT ADJUSTED BACK TOO FAR. IF THIS IS THE CASE LOOK FOR SOME ADJUSTMENT WHETHER IT BE SHORTENING THE TOP LINK (IF THREE POINT HITCH) OR BY PUTTING IT IN THE HIGHEST HOLE AVAILABLE ON MOST BELLY MOUNT PLOWS. HOPE THIS HELPS.
Post A Followup
: Re: Re: Plough on a Super A not working!
