Re: Dead Cub Help
Posted by Bama Binder on June 11, 2001 at 19:39:08 from (63.10.120.162):
In Reply to: Dead Cub Help posted by Seabee on June 11, 2001 at 18:58:57:
It sounds to me like you have 2 problems. With a good battery and cables the starter should really spin. I would suspect that first. You can try jumpering some cables directly to the starter to see if it will spin, otherwise pull it. Pull it and get it to a good starter/alternator shop and have them test it. I believe it will test bad. If bad replace. If good, I would have to start guessing, but I would look carefully at the starter gear and ring gear to make sure they aren't locking up. Don't forget to check the starter switch. Once you get your starter sorted out and motor spinning, you need to check for compression. See if you have compression on all 4 cylinders. If one or more has no compression, you probably have 1 or more stuck valves. Let us know and we'll give you some suggestions on that. If you have compression, check your ignition. Pull the spark plug on #1 and ground it against the block and give if a few whirls to see if you are getting a spark. No spark...save yourself some time and hair and get a tune up kit, new plug wires, and a coil and replace them all. Once you have fire, if it still don't fire, rebuild the carb. The basic kits are cheap and it isn't brain surgery. If that dosen't work, send me an E-mail and I'll come pick it up and haul it off for a nominal fee. Oh and make sure your plug wires are set up to fire 1, 3, 4, 2. #1 in front. You have to make sure #1 is at TDC when #1 plug fires. I had to pull the hood off and plug out of #1 to do it. Ignition on and #1 plug grounded against the block and a light shining in the plug hole of #1 you can see the piston. Turn the engine over by hand until you see the plug spark. It should happen when #1 is at TDC. If it doesn't, set the piston at TDC on the compression stroke and loosen the distributor and turn it until the plug sparks and then tighten it. It will be close enough until you can get a timing light on it. Good Luck...BB
Home
| Forums
Today's Featured Article -
History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
