Re: Hydraulic Cylinder Leaking
Posted by Zonie on June 12, 2001 at 18:38:37 from (64.12.101.169):
In Reply to: Hydraulic Cylinder Leaking posted by 1PWRFULH on June 12, 2001 at 17:51:29:
It does sound as if the piston seal is leaking, the oil won't come out until the piston is pushing it out. If you have dirt in the cylinder it WILL destroy the sealing ring, more likely you have rust in there which is worse. I'd take the cylinder apart and get all new seals, orings and such. Take a cylinder hone to remove the dirt/rust you'll probably need to extend the hone's shaft somehow. Only hone lightly, you don't want to remove anymore than necessary and thoroughly clean all parts. You shouldn't need any return line as the H's hydraulics use only one hoseas supply and return. The port you refer to as the return port should have a vent plug installed this will keep out the dirt and moisture and allow the air to go in and out as necessary, and make sure the vent hole isn't pointing at you while sitting on the tractor,don't ask how I found this out. I just went thru all this with my H recently, with a cylinder bought at a scrap yard. you should be able to get the seals from a local hydraulics repair/supply outfit. they should be relativly inexpensive ( mine cost about $10.00 for every seal in 1 cylinder !)and now it doesn't squirt oil all over the neibors car anymore! this can be embarassing!
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
