Re: F20 help
Posted by TMAC on June 12, 2001 at 19:20:23 from (204.116.62.49):
In Reply to: F20 help posted by Kenny on June 12, 2001 at 08:25:35:
Is the exhaust black(fuel too rich)at idle? If so you will need to adjust the carb idle screw. Older-than-six-month gas in the tank maybe? Timing is checked be fully retarding the spark and cranking #1 to top-dead-center. Then look in the hole on the flywheel housing. There should be a 'D' mark. This is how it is on a F30 and I believe the same for F20. If OK check your mag wiring. #1 is marked on the mag. Check each wire clockwise. Rice Equipment has many F series parts.
Post A Followup
: Re: Re: F20 help
