Re: Re: Re: Re: Re: transmission dripping
Posted by bleedinred on June 12, 2001 at 19:41:03 from (198.81.17.187):
In Reply to: Re: Re: Re: Re: transmission dripping posted by greg on June 12, 2001 at 09:29:27:
Hi Greg,
Pull the inspection cover off and you will see there are two shafts in the front of the transmission case. The upper one is the power shaft(clutch shaft)in, the lower one is power out to the hydraulic pump. Chances are one or both are shot. You will have to pull the cotter keys out of the sleeves on the hyd. pump drive shaft and drop the short shaft segment out, then you can get a light up there for a good look-see. The yoke on the trans shaft unscrews, and then you can get to the seal and bearing easily. If it's the upper you will have to unbolt the yoke and split the tractor between the trans. and the clutch housing far enough that you can get the bearing holder off. Those seals are fairly common items--got mine from a bearing jobber, or CaseIH can order them for you... Good luck
Wes
Post A Followup
: Re: Re: Re: Re: Re: Re: transmission dripping
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
