Re: Advice about buying a Farmall H
Posted by KURT on June 13, 2001 at 02:55:10 from (64.109.118.246):
In Reply to: Advice about buying a Farmall H posted by Dan B. on June 12, 2001 at 18:02:44:
I have an H and I checked the following stuff. Engine compression, 90 psi out of all 4 cylinders. look for welds and/or cracks in the block,transmission, and rearend. is it tough to start, how is that steering mechanism. throttle control, response and stuff, all 5 gears work, 5th gear may stall the motor-you may have to be on a decline to start going in the 5th road gear, which is 15mph. rust through on the tin and seat. For the hydraulics, look for leaks, response of controls, overheating, this would apply to the engine too. make sure all the controls work with full range of travel. Drain out fluid from the engine and hydraulic system check for water or other non petroleum. Fluid level in the transmission is indicated by a small 1/4 pipe plug on the side which is the overfill indicator. The trans holds 24 quarts of 90 weight. the engine holds 6 quarts. the radiator holds 4.2 gallons. test drive and let run for a good 30 minutes or so. Good luck and let us know. You should be paying 2000 to 3000 or so I guess.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
