Re: Bleeder valve on Lift-All breather cap?
Posted by PaulH on June 13, 2001 at 14:00:40 from (151.142.252.11):
In Reply to: Bleeder valve on Lift-All breather cap? posted by Lowell Davis on June 13, 2001 at 10:32:08:
If the original Lift-All is only a reservoir, you might want to disconnect the coupler between the belly pump and the transmission counter-shaft.
I have a similar leakage, with a different set-up. I'm using the belly pump with the factory remote valve. I have a 3-point hitch, and keep the main lift lever wired back. The manual says to close the vent when using the remote, but if I do, it builds up pressure (about 3 psi) in the system, and blows oil out through the pump drive shaft seal. The remote valve returns oil through the original filler tube, and if the vent's open, it bubbles constantly out the top of the filler tube. I lengthened the tube, which helped but did not stop the leakage. I guess I may have to drop the belly pump again (just did a clutch) and replace the seal.
Anybody else run into this and come up with a cure?
Post A Followup
: Re: Re: Bleeder valve on Lift-All breather cap?
