Re: H needs more compression
Posted by KURT on June 13, 2001 at 14:38:58 from (63.212.150.205):
In Reply to: H needs more compression posted by Dan on June 13, 2001 at 10:04:22:
I dont know if this will work but is worth a
shot. First if the craters in the head are
not that bad, and if you get 55 psi there
is at least half of the normal compression then
you could take the head to a reputable machine
shop with a surface grinder large enough
to handle a M head. And they would have to
probably grind off .025" or so (Iam guessing)
This would probably cost $250 or more. Then
with a new head gasket the compression would
go up a little. Or just get another head
from another M. You may want to show a
picture of the head (a close up of the worst
parts) and have a small scale next to the
craters to show how deep they are.
Post A Followup
: Re: Re: H needs more compression
