Re: What are the symptoms of a burnt valve?
Posted by Havin Fun in Mo on June 13, 2001 at 15:09:08 from (64.196.152.18):
In Reply to: What are the symptoms of a burnt valve? posted by Will on June 13, 2001 at 14:09:58:
Since placing oil in the cylinder did not change the compression rating, I would agree that it sounds like a burnt valve. When you put oil in the cylinder, it flows out around the piston and briefly will seal any gaps there. It will not seal other leaks such as, burnt, broke or sticking valves or cracks in block or head (these usually do not bleed off enough compression to be noticeable)
Whatever is wrong in that cylinder, it is nothing small to bleed off that amount of pressure.
Good Luck!!
Post A Followup
: Re: Re: What are the symptoms of a burnt valve?
