Re: Re: Can hole in exhaust manifold cause burnt valve and missing?
Posted by Denny Frisk on June 14, 2001 at 05:43:00 from (12.4.181.2):
In Reply to: Re: Can hole in exhaust manifold cause burnt valve and missing? posted by Bill B on June 14, 2001 at 04:38:51:
Exhaust valves normally run about bright red to orange hot in all gasoline engines that are working at full load. Thats why they use special steel alloys for exh. valves that can withstand temps over 2000 to 2500 Deg. The old slow running low comp. engines are exceptions to this, but the 560 runs fast enough to qualify. Even the exh. manifolds glow dull red over the exh. ports of the head. Makes those old Gas tractors ALL the more amazing that they still run as good as they do!
Post A Followup
: Re: Re: Re: Can hole in exhaust manifold cause burnt valve and missing?
