Re: 300U PTO Slipping?
Posted by Dennis on June 14, 2001 at 10:10:50 from (128.227.219.228):
In Reply to: 300U PTO Slipping? posted by scott Tolbert on June 14, 2001 at 09:35:28:
THe retractor bands in the PTO are out of adjustment. Run a search in the archives of this site and you will find some great replies to your question as I had the same problem a little while back. Good luck.
Post A Followup
: Re: Re: 300U PTO Slipping?
