Re: F12 running but one more question
Posted by MikeH-Tx on June 14, 2001 at 17:38:51 from (208.2.106.84):
In Reply to: F12 running but one more question posted by Brian on June 14, 2001 at 05:38:45:
Yes, I have a similar problem. If I let mine set for a couple of weeks, I end up having to clean out the carb to get it going. I need to remove the carb and do a thorough cleaning.
Check these things: After a crank or two, open the drain on the carb. If you have gas there, the fuel pump is ok. Check spark by removing one wire and placing near ground. Crank and verify spark (don't do this just after draining the carb). If both of these look good, you might have the same problem I do: a dirty carb (since it will run, you know timing is ok and compression is ok).
Post A Followup
: Re: Re: F12 running but one more question
