farmall H trans fluid changeout
Posted by Bradley on June 16, 2001 at 09:31:32 from (63.212.144.134):
I have a Farmall H and I would like to change
the transmission fluid. I know that
the fluid is a 90weight and is 6 gallons
but will all the fluid drain out of the
rear plug or do I need to take off the
front small plug to get all 6 gallons out.
And should I put kerosene in the trans to
get any solids out of the trans case? THis
might cause the trans to leak if gaskets are
worn. Thanks in advance.
Post A Followup
: Re: farmall H trans fluid changeout
