F-20 Differential
Posted by Al P. on June 16, 2001 at 14:59:32 from (206.97.113.157):
I have a 1938 F-20. the diferential noise is very loud especially in high gear. i took it apart today and found that the ring gear and pinion gear both have significant wear and there are cast iron filings in the bottom of the case. is this a common ailment on these tractors or will i have good luck getting the parts i need from another tractor? this tractor was run for an undetermined amount of time with very little lube in transmission.
Post A Followup
: Re: F-20 Differential
