Re: How remove steering wheel ?
Posted by The Red on June 18, 2001 at 03:59:16 from (12.75.196.135):
In Reply to: How remove steering wheel ? posted by Normag on June 17, 2001 at 21:26:26:
Moose's idea will work fine. If you are not going to use the steering wheel again, use a Sawzall with a metal cutting blade and cut down into the keyway. Then use Moose's suggestion with the chisel to open it up a tad. Then your puller should beable to get it off.
Post A Followup
: Re: Re: How remove steering wheel ?
