Re: Re: Re: Re: Re: H battery won't charge
Posted by The Red on June 19, 2001 at 04:27:31 from (12.75.196.51):
In Reply to: Re: Re: Re: Re: H battery won't charge posted by jimbub on June 18, 2001 at 19:08:40:
Remove the regulator cover and make sure the points are closing when the engine is running. There will be either a spring adjustment arm or a screw to adjust the points if that is the culprit. If it is, make sure they open as you are shutting down the engine. Otherwise it will drain the battery quickly!
Post A Followup
: Re: Re: Re: Re: Re: Re: H battery won't charge
