Re: Re: Distributor update
Posted by FC on June 19, 2001 at 08:37:57 from (208.14.16.15):
In Reply to: Re: Distributor update posted by Kendall on June 19, 2001 at 07:46:04:
Cam rotated nice and free. However, I did clean with penetrating oil a while back. You are right in that holes are worn some. I have ordered new springs. I am considering measuring dia. of pin, and brazing up holes then redrilling to correct size, greasing, and reassembling. I know the brass will not last as long, but I will definitely get my moneys worth out of it (free) vs. $65 for new weights. Tractor is not in heavy use anyway. Nice tight springs might do the trick alone. It almost seems that when I cleaned it all out it freed up everything allowing timing to "float" more due to wear. I think cam was initially stuck allowing no timing movement.
Post A Followup
: Re: Re: Re: Distributor update
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
