Replace the buttons as IHparking indicates. The adjustment should be very near what it is now, and use locktite on the threads as the original interference fit might be compromised. The wear indicates that the Throwout bearing was not healthy at some point in the tractors life (I would replace it now for sure. Dry splines are potentially a cause of the disk not centering in the open space when the clutch is depressed. The resulting drag can cause gear clash. Clean them up with a round wire brush, and use a light coat of LPS brand corrosion inhibitor on them and the shaft. The friction pads look good to me, I would compare them to new and if less than .020" thinner, I would re use the disk as is. Pilot bearing replacement is also needed. Looks like a good tractor will result from your effort. JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
