Re: Re: Greasable Hubs?
Posted by Brent on June 20, 2001 at 10:32:44 from (208.165.125.155):
In Reply to: Re: Greasable Hubs? posted by Jim on June 20, 2001 at 08:17:02:
In the kit I bought from Case/IH it had new bearings and races, a dust cap gasket, a seal, and this tinny round thing which was the first item I slid over the spindle. Is this supposed to be pressed on into the hub to hold the seal in tight or something?
Post A Followup
: Re: Re: Re: Greasable Hubs?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
