Re: Greasable Hubs?
Posted by Steve from MO - huh? on June 20, 2001 at 11:00:59 from (168.166.10.4):
In Reply to: Greasable Hubs? posted by Brent on June 20, 2001 at 04:12:48:
Unless memory completely fails me, these seals were a press fit in the hubs. I am sure someone will tell me if I am wrong on this.
There should not be any space between the hub and seal because there isn't any movement there. Are you sure you got the correct seals?
Post A Followup
: Re: Re: Greasable Hubs?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
