856 Diesel
Posted by Joe on June 20, 2001 at 19:43:26 from (216.165.155.64):
When I run my 856 at high thottle (1800 rpm)for any length of time it cuts out. Thru experimenting I have found that if I remove the timing cover on the side of the injector pump (Roosa Master) or remove the fuel return line it will run fine. So I checked for a plugged return line it was clear. Then I checked the check valve in the return line and it seemmed dirty so I replaced it.That seemed to help at first but now it does it again.If Irun at part thottle it works OK.What is the need for the check valve? A 190 AC w/a similar Roosa Master doesn't have a check valve.Does anyone have any idea what to try next? Has anyone had this problem? Thanks Joe
Post A Followup
: Re: 856 Diesel
