Re: Re: Re: PTO oil leak
Posted by Haas on June 21, 2001 at 05:18:20 from (129.37.117.103):
In Reply to: Re: Re: PTO oil leak posted by John Shuler on June 20, 2001 at 19:05:23:
If the bushing is there, you would not know it unless you take the seal holder off. Then you can slide the bushing off the shaft. The bushing (or spacer) is on the shaft between the ball bearing and the belt pulley and it runs against the seal. I suppose it may get stuck on there so could be hard to get off. If the bushing is missing, there will be a space between the seal lip and the shaft. Sounds like yours is OK. I don't have an A, but I think the C is the same. The part number for the C is 43630D. The parts book calls the part a spacer. If the seal is leaking because the bushing is worn, it would be easy to replace the bushing which would renew the surface that the seal runs on. Your leak could also be caused by a worn bearing, allowing play in the shaft that the seal can't handle.
Post A Followup
: Re: Re: Re: Re: PTO oil leak
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
