Re: Hauling the Farmall H
Posted by Denny Frisk on June 21, 2001 at 05:38:05 from (12.4.181.2):
In Reply to: Hauling the Farmall H posted by Dan B. on June 21, 2001 at 03:04:22:
My Super H used to weigh 5250# with fluid & 1 set of weights. Weights are 145# EACH, so figure 300# for the pair with bolts; Fluid if the 11X38 or 12.4X38 tires are "FULL" to the top of the rim are supposed to hold just shy of 500# of calcium chloride solution EACH. I think HAAS is close on His estimates for the weight of the loader & mower. Sounds like You should be O-K with your tow vehicle & tandem axle trailer! Tie everything down good! If Your Super H falls off the trailer I may pick it Up!
Post A Followup
: Re: Re: Hauling the Farmall H
