Re: Need help with H transmision problem
Posted by Bob M on June 21, 2001 at 15:12:08 from (66.66.72.246):
In Reply to: Need help with H transmision problem posted by TBW on June 21, 2001 at 14:19:00:
That rapping you're hearing is caused by the U-joints on the PTO shaft - and it is normal. Happens whenever the PTO input and output shafts are not parallel (as in turning). The greater the angle difference the more pronounced it gets. Can be minimized making sure both front and rear joints are assembled "in phase" with each other, using the longest possible shaft (to minimize shaft angle) and by making wide turns.
Post A Followup
: Re: Re: Need help with H transmision problem
