Farmall Tractors Discussion Board
Re: SUPER M SERIAL NO.
Posted by K-Mo on February 23, 1999 at 18:24:28:
In Reply to: SUPER M SERIAL NO. posted by BUCK on February 21, 1999 at 14:41:03:
Buck,
I think you might be looking at the Block Casting Number.
The numbers you give are confusing. The 8-264 is probably 'C-264'. Could your 356980PL acutally be 356980R1?
The tractor serial number is on an ID Plate on the left side of the Clutch Housing. On a standard Super M, the serial number will look something like-- SM12345
Kent
Post a Followup
: Re: Re: SUPER M SERIAL NO.
