Re: How do I check my Oil Pump on my M?
Posted by jakee on June 24, 2001 at 21:33:34 from (64.12.103.24):
In Reply to: How do I check my Oil Pump on my M? posted by Dave on June 24, 2001 at 20:34:47:
check with your dealer and see what end play is supose to be between the plate and the gears,you can use plastic gauge to measure it ,and also check the spring in it to make sure it,s not wore thin on one side,they are perrty hard to destroy.
Post A Followup
: Re: Re: How do I check my Oil Pump on my M?
