Farmall Tractors Discussion Board
Re: Farmall A starting problem
Posted by Farmall Gray on February 23, 1999 at 19:02:14:
In Reply to: Farmall A starting problem posted by Todd Stellhorn on February 16, 1999 at 22:59:32:
One way to find out if it is flooding, shut the fuel off at the tank and let it run till it runs the carb dry and shuts off. Then turn the gas back on and start it the way you normally do. If it starts Ok then you need to look futher into the fuel system. If it doesn't, you need to look
for another problem.
Post a Followup
: Re: Re: Farmall A starting problem
