Re: Re: Re: Re: Stumped on C problem
Posted by FC on June 25, 2001 at 13:06:50 from (208.14.16.15):
In Reply to: Re: Re: Re: Stumped on C problem posted by Andy Martin on June 25, 2001 at 12:16:08:
Could very well be plugged idle circuit, but I tried to blow out all passages while carb was off. I also wondered about vacuum leak on intake causing this. Obviously has some of the same symptoms of a lean engine. I will try holding throttle closed, but I am fairly certain it will die, as many times it will die if I pull throttle back to idle quickly. As I said it runs fairly normally at high throttle.
Post A Followup
: Re: Re: Re: Re: Re: Stumped on C problem
