706 wont start
Posted by scooterhead on June 25, 2001 at 16:11:53 from (208.129.162.125):
I was mowing hay , about 4 hours , stoped to talk to somone and it started to sputer a bit then smothed out then again then died before I could get back to it . There was plenty of fuel in the filters , there was alot of air at the pump but after bled out it wont pump into the injector lines . It was running fine .706 Farmall , 310d engine with Bosch pump
Post A Followup
: Re: 706 wont start
