Re: Need info on PTO cover...H
Posted by Wayne Swenson on June 25, 2001 at 20:31:55 from (206.9.158.207):
In Reply to: Need info on PTO cover...H posted by burns on June 25, 2001 at 18:30:55:
You are looking for part # 55013 DXA which was supplied on tractors serial # 15878 to 117999 when the 1 1/8" diameter PTO shaft attachment was ordered.
The longer style PTO safety shield was supplied when the 1 3/8" diameter shaft became the industry standard for 540 RPM. IH made the change at serial # 118000. Earlier tractors could have the later style large shaft PTO attachment retro-fitted if the correct transmission countershaft gear was installed. Look in your H & HV parts manual for further information.
Post A Followup
: Re: Re: Need info on PTO cover...H
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
