Re: Farmall A carb
Posted by Dave U on June 26, 2001 at 05:56:07 from (162.70.223.166):
In Reply to: Farmall A carb posted by Norman on June 25, 2001 at 17:34:15:
You might want to check the archives on this post. I remember this issue. I know on my A it doesn't seem to matter where the idle screw is set. The idle doesn't change. If I remember that was to majority of the replys to this.. Adjusting the governer seems to make more of a difference. Your A maybe just have too low of an idle setting.
Post A Followup
: Re: Re: Farmall A carb
