Re: Farmall A carb
Posted by Dave G on June 26, 2001 at 10:27:30 from (205.175.225.23):
In Reply to: Farmall A carb posted by Norman on June 25, 2001 at 17:34:15:
The idle mixture screw should make a difference when turned in or out. If it doesn't clean the air passages like the other guys say. If you can get a manual that shows where they are, sometimes they are easy to miss. When you get it cleaned out adjust the mixture when engine is warmed up and set midway between the rich and lean rough idle points.
Post A Followup
: Re: Re: Farmall A carb
