Re: Farmall A carb
Posted by Norman on June 26, 2001 at 11:34:25 from (206.206.120.148):
In Reply to: Farmall A carb posted by Norman on June 25, 2001 at 17:34:15:
Thanks Guys, EMBARRESED! EMBARRESED! The other day I noticed a little metering tube like dohikky on the table where I work on the carbs. It was old looking so I set it aside. I took the carb apart this morning while looking at the book. Oh oh. I had put just a drill port plug where that other thing went. It went in just below the idle screw from the inside. It now makes a difference when I turn the idle. What else can you expect from a bird that has Green Disease. All seriousness aside I am really enjoying this little "A". It's for a guy in Tucson. Now my wife want's to keep it. Thanks
Norman
Post A Followup
: Re: Re: Farmall A carb
